Older Utica Gas Boiler
Steve Proto
Member Posts: 1
I'm having an issue with an older Utica Boiler that doesnt stop heating the water in the furnace eventually passing the boiling point and relieving itself via the pressure relief valve. Its already claimed the ciruculator pump so that was replaced with a Taco 00 Unit. The flow is in the proper direction and the air was purged correctly from the system as all pipes are hot. Not sure how the temperature is regulated on this unit.
Relief tripping
I think it would be best if you call a local professional in your area. Something is not cutting out the burner circuit and this is very DANGEROUS. Not something you want to play around with.0
