Best Thermostat for Steam System? Mine may be bad.
JohnNY
JohnNY Member Posts: 3,354
....Honeywell T87.
I find it works best with the slow reaction time and limited flexibility of a steam system
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=290&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
Consulting & Troubleshooting
Heating in NYC or NJ.
Classes
  • JJJJJ
    JJJJJ Member Posts: 12
    What is the best thermostat for a more than 70 year old steam heating system?
    I have a Dayton Fuel Trimmer, Model 2E501B. I believe mine may have gone bad this evening. I turned it down from about 72F to 60F for several hours to cool the boiler to add water. When I returned the thermostat to 72, the boiler did not fire up, even though the temperature had dropped on the thermostat to about 67F. The pilots are lit on the boiler.
  • BillW@honeywell
    BillW@honeywell Member Posts: 1,099
    You could use....
    our VisionPro 8000 if you need a top-line touchscreen programmable. The FocusPro 6000 is a good alternative if you are on a budget, and still want a programmable. If you have cooling as well, these stats will control that also. If you want a non-programmable, the Focuspro 5000 is a great choice. All are compatible with steam, mercury free, 5 year warranty, very simple to use, and the programmables are EnergyStar rated. They are available from your local heating cooling contractor.
  • brucewo1b
    brucewo1b Member Posts: 638
    T87F
    If yoiu can't buy them and you can't install them why mention them
  • Guy_6
    Guy_6 Member Posts: 450
    t-stat
    Be careful blaming the thermostat. What you have described may not be the stat at all, but a boiler that has shut down for some other reason. A plugged pigtail on the pressuretrol giving a false read, or a low water issue.
    Thermostats are fairly durable, so I would look toward the system first. As a homeowner, I would not go much further than ascertaining a correct water level in the boiler.
    After that I would strongly suggest bringing in a pro.
