Open system question
Wayco Wayne_2
Member Posts: 2,479
when I first installed radiant floors I would take hot water right off the domestic potable water heater and run it through the pex tubing. Then I learned of the possble health risks and started seperating the system water from the potable using flat plate heat exchangers. I was discussing this with a friend who is also an HVAC contractor. He asked me what the risks were for any bateria or legionella in the flat plate on the potable side. Hmmmmmmm. The big difference to me is water volume. There is far less volume in a flat plate than in a radiant floor system so "less" risk by proportion, however that is not the same as "no" risk. What are your thoughts on this. WW
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=255&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
pipe it
for a trickle of gravity flow on the pot side & that eliminates all of the four conditions the bugs like
Gravity flow
> bugs like
> _A
> 98&Step=30"_To Learn More About This
> "Find A Professional"_/A_
Gravity flow
> bugs like
How would you do this, Dave? Just make sure the plate is higher than the WH?0
- 86.3K THE MAIN WALL
- 53 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 100 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 64 Pipe Deterioration
- 917 Plumbing
- 6.1K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 41 Industry Classes
