Combination Gas/Oil Boilers ??Residential??
Chuck_20
Member Posts: 13
Does anyone know of any manufacturers building combination gas/oil boilers for residential use? (Less then 200 mbh)
Duel fuel
does not exsist for residential that I know of. There are a few that have certified both gas and oil burners for the same unit (Biasi for example).0 -
Not for this season,
but I know of three getting ready for next year. Two of the usual suspects, possibly one new player.0 -
Hydrotherm has the smallest units I've seen
But they are still in the 400,000 range,I think. Also, have been very unimpressed with Meztek/ Hyrdrotherm. Poor quality, poor design and poor factory backing. The kind that makes good local reps pull thier hair out.
Boilerpro0 -
ouch
There have been some interesting changes at Mestek in the past year or so, and the results of those changes are visible in both product and support.
You apparently had some negative happening in the past, and I apologize for that, and I am not going to to beg for another chance. All I ask is for you to wait and watch. You will see the difference.
Guy Woollard
Smith Boiler Co./ Mestek
- 86.7K THE MAIN WALL
- 56 Biomass
- 105 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 69 Pipe Deterioration
- 949 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
