Software
zeb_3
zeb_3 Member Posts: 104
What software do ypu guys use for heat gain calculations?
  • Firedragon_4
    Firedragon_4 Member Posts: 1,434
    I've used this for twenty years,
    never let me down and the first three are on-the-house!
    http://firedragonent.com/Software.htm
  • A.J.
    A.J. Member Posts: 257
    I'v been using Wrightsoft
    for about three years. It will just about do it all (loads,duct lay out, radiant, or proposals. If you are looking for a program that can do it all this is it but there is a steep learning curve and the price is a bit steap if your buying more than one modgual at a time.
    Kupetz's Plb & Htg
  • Paul Pollets
    Paul Pollets Member Posts: 3,666
    I use
    The Wirsbo ADS program for radiant or cooling loads and The slant-fin program for radiators only; HVAC CalcPlus for ducted loads.
  • pitman9
    pitman9 Member Posts: 74
    Wrightsoft's offerings
    If you're just doing heat losses many programs will suffice. Once you start doing duct design something like Right Suite with J, D and Draw can't be beat.
    I've been using it for about 2 years now. I plan on going to one of their training seminars but I can do a home layout with ductwork in under an hour from start to finish.
  • Constantin
    Constantin Member Posts: 3,796
    For heat gain,
    HVAC-Calc is pretty decent. See my updated homeowner review on HVAC-Calc on my web-site. If all you're doing is calculating heat gain, or you cannot afford the pricier alternatives, this is a good start and easy-to-use.
