Certified fuel savings
Michael Gray
Member Posts: 6
Rentar Fuel Catalyst just completed testing at Industrial Combustion's lab in Monroe, Wis. On a factory-fresh, NYC-speced MEG-034 we had a 13% gain in efficiency. IC was not sure on the results, so the test was redone with better water measurement and showed an 18% gain in efficiency as measure from the baseline. That is steam produced vs fuel use. Give Todd Wymbs or James OBrien from Rock Mills Boilers a call for further information.
- 86.7K THE MAIN WALL
- 56 Biomass
- 105 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 69 Pipe Deterioration
- 949 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
