Roth Oil Tanks
Looks like stainless. Regardless, they are a very good tank. Have had no problems with them as of yet.
  • Maynard
    Maynard Posts: 74
    Roth Oil Tanks
    I am going to replace my 275 oil tank in my basement. Any opinions on the Roth double wall oil tanks? Cost versus steel tank?
  • Ken D.
    Ken D. Posts: 836
    Roth
    We have installed many Roth tanks. They cost more than the standard steel tanks, but have a leak proof design and are stainless steel with a poly lining. What we have installed do not have a bottom drain, so you have to draw from the top. They do have a smaller foot print than standard, but are taller. They probably will last a lifetime, so the extra cost is worth it. So far, we have had no problems.
  • Joe Brix
    Joe Brix Posts: 626
    Galvanized
    not stainless, right?
  • Roth tanks
    Have three in my house and chose Roth after installing some of the other 2 makes available. Like the set up and ease of piping, especially the duplex and triplex piping manifolds. And they are galvanized, not stainless.
  • galvanized
    The tanks are galvanized not stainless. We have installed about 10 and have had no problems. I also have one in my own home. They are about 30% more than the Granby steel tank but well worth it IMHO
    Dan G
  • Just a note
    Make sure to use only Roth parts for the install. You definitely have to use the Roth vent alarm or risk overfilling and a spill.
    Also make sure to go with a one pipe set up only. The directions say 2 pipe, but a call to Roth says one pipe. Appaently a 2 pipe set up can lead to a spill. It happened to us.
