Sdhw ???'s for Constantine
Constantine: can you fill me in on your sdhw setup and its performance thus far,
Did you use the vitocell 300 dual coil tank?
What collector, tank, return, differential temps have you setup, Have you found an efficient operating groove yet?
Did you install a solar powered pump, If so which one?
Do you know the temp of the glycol in and out of the tank coil?
Would like to compare my very simular Thermomax system.
Best reguards
Brendan.
