I'm Baffled
David Sutton_6
David Sutton_6 Member Posts: 1,079
is to lock out the burner and run the circ cool the boiler right down. the steel will contract and give a bit more room. dosent always work but worth a try...David
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=386&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
  • Tony_25
    Tony_25 Member Posts: 26
    I'm Baffled
    How do you get baffles out a steel boiler when they are stuck in there. I have run across a few New Yorker and Ford boilers that the baffles are stuck in the flue passages. I quess they are stuck because they were never cleaned or maybe they were washed down with water.
  • Bill Nye_2
    Bill Nye_2 Member Posts: 538
    I use
    I use a big pair of channel locks. Pull and twist. You mean there are still ford boilers out there that haven't leaked or burner through?
    Some times when they haven't been cleaned, the excess heat burns the metal and expands the bottom of the baffle.
