Y-Strainer....has anybody seen ??
Brian_18
Member Posts: 94
Have any of you ever seen Bronze Y-Strainers with isolation valves built in? You know, by the time you attach a couple of valves to a 1.25" stainer.....it becomes very cumbersome. Maybe somebody makes them with built in valves for a much "Cleaner" look.
Here's some nice-looking ones from Yorkshire Fittings
Unfortunately they're from the UK. Don't know if they're available with NPT threading or in bronze.0 -
Several
Nexus Valve, Hayes Fluid Controls has them to 1.5 inch size. MEPCO and others do too.
http://www.nexusvalve.com/
Pipe valve packages are becoming more commonplace and the quality is good.
Combo packages have strainers, constant flow valves, balancing valves, hose kits... a lot of "making up" can be saved.
Those Nexus components are beautiful!0
- 86.3K THE MAIN WALL
- 53 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 100 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 63 Pipe Deterioration
- 917 Plumbing
- 6.1K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 41 Industry Classes
