too much venting?
chris_68
chris_68 Member Posts: 18
In a single pipe steam system, can you have too large a main vent? I was going to use a gorton #2 toward the end of the main where an old raidiator used to branch off from (only a capped t now)and then put a smaller vent where the current vent is at the end of the dry return. I have about 40 or so feet of 2.5 inch main that then tuns into a 1.5 inch dry return for about 25 feet. Thanks for the advice.
