Weil-mclain ro2-w-6 series 4
Guy_6
Guy_6 Member Posts: 450
It sounds like what we call a SNOWMAN, as it was a series of round sections stacked vertically. The now unfortunate part was the lightweight fireproof insulation that was adhered to the outside of most of those units. They were a durable boiler, but I have found them to be less than efficient due to the wide open flue passages. We used to put fire brick inside the passages to slow down the exhaust gases, but we had to be careful not to slow them too much.
At this point, that boiler has paid it's dues and should be replaced.
  • Mark_72
    Mark_72 Member Posts: 53
    weil-mclain ro2-w-6 seires 4
    Can anyone direct me to info on this oil fired boiler?
  • Rodney Summers
    Rodney Summers Member Posts: 748
    Weil-McLain
    Mark, Are you sure about the model number because it is not familiar to me.
    See if you can get any other info like its size, is it steam or hot water, how many sections, residential or commercial application.
    Or,
    http://www.weil-mclain.com/literature/literature.htm
    Robert O'Connor/NJ
  • Mark_72
    era 1955 fire box door reads when inquiring use Ro2-W-6 series 4, This is all I can find on the unit. It is a round boiler about 5' tall
  • Al_19
    Al_19 Member Posts: 170
    Try this in the Beacon Boiler books in the Library section of this site.
    http://www.heatinghelp.com/pdfs/197.pdf
  • Al_19
    Try this in the Beacon Boiler Reference Books in the Library section of this site.
    See page 7 of 20.
  • Mark_72
    That helps.
    Thank you for the help
  • Mark_72
    It looks like it could be a snowman.
    I know it's time to change it out I'll do a heat loss on the house and speak with the property owner. I just had'nt the plesure to work on this model and could not fine the info on weil-mclain's site. Thanks for your help. It still makes domestic hot water with the 6gph tank.
