MMA zone valves, need distributor information
Richard Daas
Member Posts: 1
I really hope you can help. I have recently been called to
service a boiler system in a church. There are 3 zone valves that are not opening, among other problems. These
are unlike any valves I have encountered before. They bear the letters MMA, are a heat motor type and carry no other
information. The plastic case is approximately 2 inches
square, two-tone gray with the top cover being opaque. The controllers attach to the brass valve body by means of a threaded nut. A plastic lever on the end may be turned
180 degrees from "AUTO" to "ON". It also has an LED indicator. I hope I have given you enough information here.
Do you know who manufactured this valve? and/or parts available. They are in a difficult to replace location and
service parts would be wonderful.
- 86.7K THE MAIN WALL
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 939 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
