gray mercury?
964655
964655 Member Posts: 2
  • GusHerb
    GusHerb Member Posts: 91
    gray mercury?
    Does anyone know why mercury in a thermostat would turn gray and seem sluggish to get across the tube?
  • BigRed
    BigRed Member Posts: 104
    Mercury
    I have seen this befor as well I speculate that the mercury was bad all of my finds where on new installs, I installed about 350 in an apartment building and I had about 4 of these sandy mercury thermistats. I dont even know if mercury can be bad. Maybe it was the amps.
  • GusHerb
    ive used other thermostats of the same model on this system without this problem and the mercury was fine before install
  • 964655
  • GusHerb
    why newer tstats
    i have two of these thermostats both used and with gray mercury bought from diffrent places but bought in the same year. i also have an old gold one with good mercury. could honeywell be sabbotaging the mercury of these newer round thermostats.
  • Empire_2
    Empire_2 Member Posts: 2,340
    Gray mercury
    I believe it is a contamination sign. When it is open to the air and electrical current is passed thru, I think this is the result. I to have seen it in the past.
  • GusHerb
    if it were open to the air wouldnt it of gotten out?
  • Empire_2
    Im thinking either the seal has failed or glass with small crack.
  • GusHerb
    the gold tstats ive never had a problem with its only the newer ones i bought.
