Solar Collectors
Solarstar
Member Posts: 81
Yes I,m oversized by about 40% ...Good Eyes for seeing this,Panels are 30 deg off tru south and tilt is 55 deg for my latitude of 45 deg N. I wanted the extra BTU,s in the spring and fall for supplimental heating that I do not have in place yet. Panels heat great at any outdoor temp of course...Also my above average water usage gives me quicker payback on such a system Paul
What is everyones preference for brands and models?0 -
Check out the Thermomax brand, pretty darn good, easily expandable, high output,good product.0 -
You talkin'
Flat rate or ejaculated tube?
Not many of them focusing constipators around any more.
I are a solar egspert...
ME0 -
Mark I used to work with a dunnerall that talked jist ike at. He were prolly a salar eggspert too.
I am pretty new to solar heat but I think I understand it pretty well as a Raadient heetin eggspert. What do you recommend for the new salar guy?0 -
Sollmax
From siliconsolar.com. They have e(?)acuated tubes and flats. Selling the e-tubes for ~$600 for 20 tubes which is very reasonable compared to other vendors.0 -
When I shopped around
for plate type I narrowed down to Solahart by Rheem/ Rudd, Heliodyne, and Chromagen.
All things considered price, shipping, availability, etc I went with Chromagen. I really like the clean glazing attachment
www.solahart.com www.heliodyne.com www.chromagen.biz
I narrowed down
to these 3 choices for plate type. www.heliodyne.com www.solahart.com and www.chromagen.biz
I went with Chromagen. Price, shipping, availability, and quality worked out best.
hot rod
I have had best luck with Heliodyne panels,,,,, VERY nice , good o-ring unions, no need to melt rubber to solder fittings been in business through thick and thin etc.0 -
Nice to hear Heliodyne is still going
I was doing a LOT of their equipment back in late 70's early 80's. Don't know if the ownership/product is the same but they were a very good vendor in those days!0 -
We've had good luck with the Solamax Brand of Evacuated Tubes by Thermomax. A little better price than the Mazdon. I feel Evacuated tube is a good choice for our foggy weather here. Leaves more room on the roof for the solar electric when compared to using Flat Plates.
Love my solarmaxs'...Paul0 -
wow bailey tell me more about your system. do you have pictures of the storage tank and piping? also how well dose it work in the winter time dose it provide enough hotwater for your entire house hold.
thanks
Jason0 -
Tank (120 gal.)climbing past 160 deg and its 1;00pm I'll send a pic shortly. Paul0 -
Solamax
Our Latest instal on a metal roof. Strut was run long in case another 30 tubes are installed once redwood hot tub is operational. (Good Heat dump if necessary)0 -
Where are you located
That's a beautiful installation. Where do you live?
How many people using hot water in your house?
How big is the collector?
That'salottahotwater. All heated with the solar collectors?0 -
We're in Northern California
The Real Northern Cal. Not the Bay area.0 -
bailey, seems like a lot
of tubes for 120 gallon of storage? Do you have other loads connected?
hot rod
Pump starts and stops with the sun, powered by that small 20 watt PV panel in the photo above the collectors. Paul0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 938 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
