dirty steam boiler
Jake_2
Member Posts: 3
I have a steam boiler that needs cleaning. I have no skim valve but a can remove the pop-off valve on top of the boiler to perform the skimming. Any tips?
call a pro
In my oponion your best bet is to contact a pro. You cannot blow down a steam system through the pressure relief valve. Remember you are dealing with water hot enough to give you third degree burn's instantly. Get a pro to come in and do it properly and safely, it's in your best interest...IMHO0
- 86.3K THE MAIN WALL
- 53 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 100 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 64 Pipe Deterioration
- 919 Plumbing
- 6.1K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 41 Industry Classes
