pressure activated bypass valve
dan holmes_3
Member Posts: 9
sounds like they are in backwards?
Who makes a good pressure activated bypass valve? I have a client with three zones with zone valves that make a racket when closing. Or, any other ideas? I'm tempted to see if swapping a 007 fot the B&B series 100 will tame the monster!? Any thoughts? Thanks in advance.
Adam0 -
ZV's
They're not, they're just fighting a big bad pump on closure!0 -
Personally,
I like the offering from Viega and Oventrop, but why not look into something that opens and closes slower for a ZV?
When I install the piping, I'll use a spring close ZV, when there is any doubt about the piping, I usually go with something that opens AND closes slowly.(Taco makes some nice ones, and a control that makes things very easy to wire). Chris0 -
Will the series 100
be enough circ to meet the load? Sounds like an expensive switch requiring yearly maintenance.
What type of ZV's? I have always zoned on the return and never had hammer noises, even with fast acting ZVs.
Shouldn't really need a PAB with three zones, but if it is the easiest fix... I've used the use the Honeywell Braukman, Danfoss and Caleffi.
Be sure to include a ball valve on one side so you can purge.
hot rod
ZV's
The current ZV's are Honeywell V8043E1012.0 -
Adam
a B&G 100 produces less head than a Taco 007.0 -
i had the same issue with banging pipes we swithed the zone valves to the return and it stopped0 -
Caleffi
Caleffi makes a great pressure by pass valves. Caleffi makes awesome near boiler hydronic materials...0 -
taco
taco makes a great one easy to install and adjust. we put one in just the other week.
Try a grundfoss super brute and put it on the lowest setting maybe that will help0
- 86.3K THE MAIN WALL
- 53 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 100 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 63 Pipe Deterioration
- 916 Plumbing
- 6K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 41 Industry Classes
