blocked gas valve vents on roof tops
Having trouble with mud wasps blocking gas regulator vents on a few rooftop units.Has anybody came across this and is there any solution to this problem to keep them clean?????
  • Joe_70
    Joe_70 Member Posts: 12
    gas vents
    here in jersey pse&g has screened vent caps.... check with you're supply house to see if they have screened vent caps
  • oil-2-4-6-gas_3
    oil-2-4-6-gas_3 Member Posts: 4
    peck vents
    they are called peck vents they are basically a 90 with a screen on the outlet end
