What thermostat is best for steam-heat?
Fred Harwood
Member Posts: 261
If the safety valve on your boiler is passing steam, you need a professional immediately. Do not wait, call now.
As for thermostats, I'm partial to the simple Honeywell T87. The builtin adjustable anticipator lets you get that 2 to 3 cycles per hour.
But find out why that safety valve blows first.
steam-heat advice
What is the best kind of thermostat for single stage/single-pipe steam-heat? Why is a relief-valve blasting away when it has never done that before?
Thanks, Scott Reid0 -
First-
What relief valve is blasting away? Second, a lot of stats can work just fine to control a one pipe system-Honeywell round, etc...But what relief valve is blasting away-potentially more important at this point!0
- 86.3K THE MAIN WALL
- 53 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 100 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 63 Pipe Deterioration
- 916 Plumbing
- 6K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 41 Industry Classes
