Some of space in the boiler room.....
Weezbo
Weezbo Member Posts: 6,231
last year i offered to set some japanese fighting fish "free" in the boiler room ...it has no drain you see... it gets a curb and a super sump pump... it took days to bring the 10+ tons of water up from 34 to the 60's... i have had the heat off in that particular slab for two days now ...i will take a temp check tomorrow... i got to think the thermal mass of the insulated Sog, water proof insulated filled concrete block walls, will keep this side warm for nearly a week,the extra ten tons of water should extend that prediction by at least half a day more :) easy :)
  • Weezbo
    Vanished *~/:) with the inclusion of this gert Bucket*~/:)
    this is my favorite job ...even if i did have to use some purple primer :) and the space it ate up for my "Dream header" ...:)all is well though as last week we managed to levitate the tank one More Time hover it about the room tie it in and fillerup:) it is alot ALOT like one of the old coal fired boilers..once shes inthere ,wellp you pretty much better maker work*~/:)
  • Constantin
    Constantin Member Posts: 3,796
    I hope...
    ... that you never have an issue with that tank... looks like a big one!
