Adobe Brick R Value
Chuck_17
Member Posts: 148
Anyone seen a reference for an R value of (8") adobe block?
I am trying to figue the heat loss of a house (used as an office) built with adobe blocks. The stuff looks like it could have been used in an eighteenth century barn.
Clay tile block
My reference says 8" hollow clay block = 1.85, if that is what you have.0 -
Came Across This Paper
http://www.ferncometal.com/adobe-paper.htm
It has some good information about adobe construction, and gives an R value of 0.25 per inch.
There is a surprising comparison between identical structures built of adobe and cinder blocks, with tremendously different thermal results.0 -
From the US Dept of Energy
Adobe uninsulated 10":
(R-value)3.5 (U-value)0.284 (weight)95.0 (heat capacity)17.9
insulated 10":
(R-value)11.9 (U-value)0.084 (weight)95.3 (heat capacity)18.0
uninsulated 24":
(R-value)6.8 (U-value)0.147 (weight)183.4 (heat capacity)34.2
exterior insulated:
(R-value)24" 15.1 (U-value)0.066 (weight)183.6 (heat capacity)34.3
- 87K THE MAIN WALL
- 57 Biomass
- 115 Chimneys & Flues
- 5.7K Gas Heating
- 107 Geothermal
- 70 Pipe Deterioration
- 983 Plumbing
- 6.3K Radiant Heating
- 389 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
- 48 Job Opportunities
