New Rite Temp Thermostat (8022C)
Weezbo
Member Posts: 6,231
- 45 F outside and she decided to turn one of the two zones down before retiring last night:) my thought is, turn the t stat to where you feel comfortable and leave it alone...:) disregard anything it might be saying :))
New Thermostat (Rite Temp) - Stays on Too long ?
All,
I have a house built in the 1930's with a one pipe steam, with a milli volt on the boiler. I recently replaced the thermostat with a digital programmable (http://www.ritetemp-thermostats.com/8022C.html) thermostat.
The system now fires up, taking about a 30-40 minutes for all the radiators to fully heat. Once the system was fully charged, I thought the boiler was supposed to go off ?
Now when the system is fully charged, the boiler cycles on and off until the Thermostat is satisfied. Is that normal ?
It seems very wasteful. Sorta defeats the purpose of dropping my heat at night and bringing it back up in the morning.
Do I need to get another thermostat ? Recommendations ?
Thanks,
Rich
I have this same t-stat
And it works just fine... I have it set for:
7:30AM = 63 degrees
9:00AM = 60 degrees
5:00PM = 63 degrees
10:00PM = 56 degrees
When the boiler comes on warm, it takes about 8 minutes to get heat in the first couple of sections and about 20 minutes to warm the all sections. Usually runs about 25-30 minutes to satisfy the t-stat. Shuts off as soon as it hits the desired temp and doesn't cycle back on until the temp drops below desired temp.
Sounds like either a defective t-stat OR something with your boiler. Is it building pressure and then releasing between cycles?
cheers
J~0 -
Adjustable Anticipation
I am having the boiler cleaned today, hopefully that will fix the short cycling when the system is fully charged. If not I am going to try to get some more info, but it looks like I might have to buy a new t-stat with "adjustable anticipation".
From what I understand of the concept, the system runs, than is forced off after a period of time. Which is what used to happend with the old t-stat.
I am going to open a tech support e-mail with Rite Temp to see what they say.
63, 56 degrees. Yikes, that is cold. Thanks for your help.
Regards,
Rich
Would love to see
The results from your tech support conversation. Hope you can share it!
cheers
J~0
- 120 Geothermal
- 394 Solar
