raise baseboard radiator
I have to raise a long cast iron baseboard, so I can install my hardwood flooring. I would like to know what will happen after I cut the pipes and drain the water.
Do I have to refill the hot water system?
Please advise,
Dave
  • jeff_51
    jeff_51 Member Posts: 545
    you have to drain the water and then cut out the baseboard
    and yes you have to refill and bleed the system
  • oil-2-4-6-gas_3
    oil-2-4-6-gas_3 Member Posts: 4
    honestly if you are asking aquestion like this you should have someone do the heating end of your endeavor --if not you will end up having a frustrating day trying to get your system running quietly and correctly after all the hair pulling etc.. you will end up calling someone in to fix it --
