radiator valves
marco_5
Member Posts: 17
Thanks for the response. I also e-mailed Legend valve, and they said basicly the same.
Marco
Marco
radiator valves
Hi guys,
this may be obvious to some so forgive my ignorance, but what is the difference between a radiator valve for hot water vs. steam? One has a hole in it that you can blow through..Is it really a shut off? If sombody could enlighten me as to which is which and what the hole is for I would feel so much smarter0 -
I'm sure there are others, but the valves I've seen for steam have a spherical body and no little hole. Was told that the valve design was to enhance the ability of condensate to flow back into a one-pipe system.
The hot water valves have a cylindrical body and a little hole. Was told the little hole was to keep a bit of water circulation at all times to help reduce the possibility of a freezeup when the valve is turned "off".0
- 120 Geothermal
- 394 Solar
