radiator issue
will smith_4
Member Posts: 259
Steve-are you positive that the radiator valve is 100% open? Possible too that the radiator could be plugged. Does it heat quickly if you take the vent off? (gotta be careful trying that!)
hello, i have a problem with a steam heating system. the riser furthestaway from the boiler , the entire riser is getting hot, the radiator on the first,third and fourth floor get hot quick, the radiator on the second floor takes long to get hot, i changed the air valve to a C the control valve is good and the pipe is not clogged! Could it be i have to put smaller air valves in the upper 2 floors? or what? i need help0
- 87.2K THE MAIN WALL
- 118 Chimneys & Flues
- 113 Geothermal
- 164 Indoor-Air Quality
- 73 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
- 49 Job Opportunities
