Fuel oil
Weezbo
Weezbo Member Posts: 6,231
Bad idea... donn do it .
  • Ed Kreuz
    Ed Kreuz Member Posts: 14
    Fuel oil
    If I have an oil boiler in my house can I convert it to burn waste oil ? Is there anything you can mix with the fuel to make it more economical ?
  • Gary Fereday
    Gary Fereday Member Posts: 427
    to economically burn any fuel
    INSULATE! the barn!
  • Dirk Wright
    Dirk Wright Member Posts: 142
    special burner
    waster oil burners are very different from standard fuel oil burners. You cannot burn waste oil in standard burners. As the other poster suggested, insulate the house to use less fuel, and wear a sweater!
  • Ron Schroeder
    Ron Schroeder Member Posts: 995
    The waste oil burners are not UL listed to be used in a house.
    Ron
