specs for ergomax and turbomax tanks
dan holmes_2
Member Posts: 11
prior to using either of them I spoke with both eng. depts you should also.What I chose the turbo max because the head pressurs required was much lower. The domestic water goes through the three eights coils not the boiler water. I have put in about 10 of them and had good results.I know other contractors who use ergo and are happy. make sure you have enough boiler input to do the job.they also need an air vent someware above them.
Does anyone have those specs for Ergomax vs Turbomax tanks circ requirements? I also couldn't find them on website.0
- 86.3K THE MAIN WALL
- 53 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 100 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 63 Pipe Deterioration
- 917 Plumbing
- 6.1K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 41 Industry Classes
