broomall vapor system traps?
john staby
Member Posts: 1
I was working on an intact Broomall vapor system and found two hoffman 17 c traps .
Since vapor traps do not trap steam, so should I take out the guts and put back them back empty or should I change the parts out. Both radiators do not and have never worked with the 17 c traps.
All other radiators work fine with the Broomall p-trap.
Thanks,
John
Thanks,
John
there is no reason
that regular radiator traps shouldn't have worked..is something else taking place here? bad trap, bad valve, bad pipe pitch? something doesn't sound right with the senario.
Serving Cleveland's eastern suburbs from Cleveland Heights down to Cuyahoga Falls.0
- 86.3K THE MAIN WALL
- 53 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 100 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 64 Pipe Deterioration
- 917 Plumbing
- 6.1K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 41 Industry Classes
