Radiant Wall
jim lockard
jim lockard Member Posts: 1,059
No Matt I think you may end up trapping moisture. J.Lockard
  • Matt_21
    Matt_21 Member Posts: 140
    i'm thinking of adding
    radiant heat to the wall between my family room and garage. i plan on removing the sheetrock in the garage and staple up joist plates to the wall. when i reinsulate and apply plywood to finish the wall in the garage, should i put a layer of plastic between the insulation and plywood as a vapor barrier?
