Looking for a Time Delay Relay
from Johnstone Supply but in the delay off version. They were stock items.
  • chuck shaw
    chuck shaw Member Posts: 584
    I am looking for
    a time delay relay. RIBD2421C, or the equivalent. I have checked local supply houses, local electrical supply houses, Radio Shack, and then finally the internet.
    I want to run a delay on start, does anyone know of a product, or if you are in the wholesale business, do you take credit cards?
    Chuck Shaw
    EBEBRATT-Ed Member Posts: 18,208
    Try WW Grainger they have several types
  • Larry (from OSHA)
    Larry (from OSHA) Member Posts: 741
    how about this
    Hi Chuck
    Is this what you are looking for?
    http://www.grainger.com/Grainger/wwg/productIndex.shtml
  • Empire_2
    Empire_2 Member Posts: 2,340
    Larry has it
    This relay will work. Depending on what you are doing with it. Dont worry about PT #'s what are you doing or what do you want it to do? Every manifacturer has pt#'s dont mean crap...
  • chuck shaw
    I tried two of that model
    I picked up two of that model, one i needed, and an extra just in case. I tried the first one, and it didn't work, would not "time out", so I tried the second, it did the same thing, I don't think two in a row out of the box would be bad, so I believe that I was misapplying the product.
    It is a pretty involved story. The bottom line, is that I have trying to hold off boiler ignition for about 30 seconds. I would much prefer to use a relay, that will give definite isolation.
    Chuck
  • Ken D.
    Ken D. Member Posts: 836
    Time Delay
    You could also use an electric heat sequencer or a thermal relay (Thermo-Disc or Klixon). The part number you quoted is made by these people; Functional Devices Inc. 310 So. Union St. Russiaville, IN 46979. You can call them and ask for a distributor in your area. Hope this helps.
  • Rich_23
    Rich_23 Member Posts: 4
    Huh...they sell a post-purge timer that would be great to keep circulators running for a few minutes after each cycle. But their relays are for 24 volts, whereas most circs need 110v...anyone know of a post-purge relay for 110v?
  • Larry (from OSHA)
    OK how about this
    alright if the easy way won't work, maybe this will:
    http://ecatalog.squared.com/catalog/173/html/sections/21/17321022.html#1013956
  • Weezbo
    Weezbo Member Posts: 6,231
    LSR from SCAN DATA ?
    logical sequencing relay ? *~/:)
  • Cliff Brady
    Cliff Brady Member Posts: 149
    Solid State Delay on Relays
    I used one of these for a delay off on a bathroom fan wired with the bathroom light. One max rating though.
    http://www.automatictiming.com/pages_atc/solidstateoutput.html
    Delay on:
    http://www.automatictiming.com/pdf_div/tsc100_data.pdf
    edit: from off delay to on delay
  • tim smith
    tim smith Member Posts: 2,875
    tim dealay problem
    Those time delays generally work, I might suggest you rotate your connections, line and load need to be hooked up correct. Tim.
  • Mike M.
    Mike M. Member Posts: 22
    Magnecraft sells what you're looking for. Here's the spec page:
    www.magnecraft.com/products/e104_sec4_pg10-11_TDR.pdf
    They're available from Mouser Electronics:
    www.mouser.com/catalog/624/1279.pdf
    You'll want model TDRSRXB-120 if powering off 120VAC or TDRSRXB-24 if powering off 24VAC (either model will switch up to 12 amps of 120VAC to control a circulator). With the square base series you can hook up Quick Connects directly to the relay. You need to understand boiler wiring to know where to put it in the circuit of course. I have one of these running a three minute circulator post purge on my boiler. Works every time.
    Mike M.
