muffled Bud
Joe@buderus_2
Member Posts: 302
Unfortunately there are times chimney noise occurs( sounds like a loud "roar" usually from the chimney. This has occured with mostly Riello burners, but also with Carlins, in chimney's of all types. Sometimes a nozzle change has helped and other times a liner. There is no set pattern that we have seen to cause this. The noise is caused by sound waves, generated by the burner, travel through the boiler and resonates when entering the chimney. The muffler install looks good. Would like to see better photos if possible. Thanks
first
replacement with new company. Swap-out ,but had to install muffler on boiler,kind of a pain to do but worked great.Boiler was very quiet.Dave0 -
Dave
What kind of burner is on the Buderus? I have never had to use one of those mufflers yet, they always seem very quiet as is with a Riello. Can you post some more pics? The work looks nice from what I can see.
Darin0 -
Reillo
was the burner.Burner made more noise than exhaust up the chimney.I'm going to save my pennies to put one on my Viessman.Sorry the photos are so big,I did a crappy job resizing.0 -
we were going to put a couple on the7 section
215's at the fire station.0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 939 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
