Termomix Valve
Jay_14
Hello,
Consider using a tekmar brass mixing valve. It comes in 3-way and 4-way configurations and in sizes 3/4", 1", 1-1/4", 1-1/2" and 2". I believe that you will find that it costs less than the ESBE /Danfoss valve.
Also, if you want to save additional money on fuel, you may want to automate the mixing valve using a tekmar 741 actuator and a tekmar 360 outdoor reset mixing control.
tekmar products are available throughout the US and Canada through your local wholesaler.
www.tekmarcontrols.com
Jay Vath tekmar Control Systems
Termomix Valve
Dear Sir:
My home has cast iron baseboard heating--oil hot water. I currently have a Termomix mixing valve ( The word "Amimat" appears on the face of the valve. The valve was made in Finland ) on the furnace. This device permits the continuous flow of hot water through the system. As a result, the cast iron baseboard units never go completely cold. The Termomix valve has thus saved us a significant amount of money, and has enabled us to have a more comfortable home. However, the Termomix is now defective and must be replaced. My heating contractor can not find a source for a new Termomix valve. Does anyone know where I could purchase a new Termomix mixing valve, or does anyone know of another device available that would serve the same function? Please reply ASAP--heating season is here and oil is sky high!!
Thanks for your time,
Bruce0 -
Bruce,
Termomix s no longer available locally, contact Acaso www.acaso.se or replace with an ESBE TV valve of similar design.
Bill0 -
We have Termomix
valves and the Amimat control heads. Give us a call at
1-800-782-9927.
Lloyd0
- 87.8K THE MAIN WALL
- 133 Chimneys & Flues
