Celotec insulation
hr
Member Posts: 6,106
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=144&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
Celotex insulation
I have a customer who we were going to do a radiant garage
slab and I instructed him to install a ridgid insulation Owens Corning blue or pink board. I stopped by the job & he installed 3/4" of aluminum coated celotex board. Any one have an opinion?
Dave0 -
3/4\" celotex
A quick Google search for celotex yielded the Knight-Celotex web site. No where does the manufacturer reference their product for sub salb installation. Their approvals are as sheathing and roof insulation. Unless the aluminum is protected from the cncrete it will soon have no effect either. See: www.aknightcompany.com/productline/producthome.asp?id=bp.0 -
Celotex insulation
I just talked to the homeowner & told him to get the correct stuff. Not worth the risk. thanks for the thoughts.
And now I'm back to my vacation.
Dave.0 -
If this is the same Celotex, it's a by-product of sugar production.
Good insulative value, but very low in compressive strength. The Celotex wallboard in my childhood bedroom could be easily compressed by the thumb of a child.0 -
celotex
One of our contractors did this on a house recently. Called in a panic & said the tubing was leaking all over b/c there were air bubbles coming up through the 'crete. We found out that the foil backing or glue reacted w/the concrete & once the reaction was done it stopped bubbling. The concrete guy charged extra for finishing the slab b/c it was full of holes & took a lot more time. At least we did'nt have to tear the whole thing up & start over. Lesson learned.0 -
No!
Back in the '80s at Bio-Energy, we had truckloads of Celotex for use in glazed solar collectors. Someone (a company VP) had the bright idea to use it on the outside of our office foundation when we added radiant to the building. It soon became waterlogged. Soon, the tulips were coming up next to the building - in February (Hudson Valley, NY). Later we discovered that ants liked to build their condos in there, as well. If you check with the manufacturer, you will probably find that it's not approved for ground contact.0
- 87K THE MAIN WALL
- 58 Biomass
- 426 Carbon Monoxide Awareness
- 116 Chimneys & Flues
- 5.7K Gas Heating
- 109 Geothermal
- 70 Pipe Deterioration
- 994 Plumbing
- 6.3K Radiant Heating
- 389 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
- 48 Job Opportunities
