floor radiant
ubeill
Member Posts: 6
need to install radiant over a wood subfloor :any feed
back about wirsbo quick-trac ?
floor radiant
back about wirsbo quick-trac ?0 -
floor radiant
QT works fairly well. Viega is the OEM
I'm doing a rather large home with the Climate Panel system AKA Wirsbo QuikTrak and it certainly has it's place WRT radiant options. A little restrictive in it's design and the 10" ACP's are not readily available through my distribution chain and recently deleated from Wirsbo's catalog but, still a good product IMHO. Very little carpentry skill is required to put the system panels in place but, be very carefull of the 20º ?T design concideration.
My experience has shown that you should keep the loop lengths under 220' (if possible) and idealy even shorter; 180-200' Choose your manafold locations VERY carefully before you screw/staple your ACPs down. Use reverse return on any manifold with more that four loops. Do the "Viegan" math and you should be ok with the 5/16" tubing dry system. proper insulation is key.
http://free.hostdepartment.com/r/radiantfloors/
