Enerroyal warm air furnace Help!!
Empire_2
Member Posts: 2,340
`Since nobody has replied I will give you some imput. You need to find out who deals, sells, manufacture's this brand. I have never seen a spec sheet that gives you deminsions of heat exchanger. (I think that is what you are asking.) Mod Ser# call it in and the Wholesaller will line you up.
Enerroyal war air with riello mectron m3 help
I am performing service on the above mentioned unit and have no literature on the furnace, it needs a new combustion chamber, so I need dimentions and so on. DOES ANYONE HAVE ANY LITERATURE ON THE ENERROYAL FURNACE OR MECTRON M3? Any help would be much appreciated!0 -
Thanks, Mike0 -
You are welcome
Glad to try and help..0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 939 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
