Radiant
Chris_54
Member Posts: 2
Can't find anyone to service in my area of the Catskills (zip 13856). Getting an F14 error...checked the wires as the manual suggested and they seem fine...there's moisture in the boiler...a little bit...this might be a problem Use a fan to dry it out?
Try
unplugging and replugging all connections to the fan. There are 2. If that doesn't clear it up, call the factory at 1-800-323-9651 X125.
Shut the power off to the unit before doing the plug thang...
ME
F14 fault
Chris,
Attached is the fault code page for the 925 board.
If you checked the wiring and still fails, you probably need a new fan blower.They are warranteed for 3 years.
Drop me an email if you need further assistance.
Rich Swatton
summitplumbing@comcast.net
Authorized Heat Tranfer Products Sevice Agent0
- 62 Biomass
- 114 Geothermal
