What is lowest temp setting for TRV?
Rocky_2
Member Posts: 89
Have a crawlspace that I would like to put a little piece of baseboard in to provide a little heat. Usually I just let it run wild and anytime anyother zone calls, it circulates through that piece of baseboard too. however, what if I put a TRV on that piece of baseboard? The system is a constant circ loop with individual zones coming off at each apartment. Since we are going to be circing constantly anyway, why not let the crawlspace baseboard control its own heat via the TRV. What is the lowest temp you can set one of these for? I would like it to be about 40 degrees. Do they make any that operates that low? Muy appreciado (thats Alaskan Spanish for "Thanks alot".
Rocky
Rocky
The minimum temp on the Danfoss units is 45 deg. F0
