Munchkin boiler help
Chris_54
Member Posts: 2
My Munchkin is giving me an F 14 error which means that the speed detected of the hall pulse is more than 130% of the desired fan speed for longer than 1 minute when the fan should be on.
This system is at my weekend house and it's a radiant heat system. The remedy is apparently to check the wiring b/c a loose connection can cause this.Hopefully that works...is anyone else familiar with this error message and have any advice?
Also...if there's anyone in Upstate New York (Catskills region) that knows of a technician that can service Munchkins let me know...
Have you tried
getting in touch with the person who installed the boiler?0 -
F 14
Chris
Call Htp and they will see if there is a tech suport person in your area.
My emailis summitplumbing@comcast.net if you haven't solved the problem.
Rich
Authorized Heat Tranfer Products Sevice Agent0
