Richardson System Venting
B. Tice
Member Posts: 206
What would be a good air vent to replace an original Richardson tee style main vent? Very few vapor/vacuum systems around here so I'm a little in the dark on venting the mains on these type systems.
That was a classic system
but if the vents have never been changed, it's probably still set up for coal firing.
With automatic firing- oil or gas- you need more venting capacity, and you need venting on the ends of the steam mains as well as the dry returns where the original vents were.
I think the closest match for the original Richardson vents is the Gorton #2. For the steam mains you'll have to measure them out to see how much air is in them. Then go to
http://www.heatinghelp.com/shopcart/product.cfm?category=2-138
to buy a copy of the latest info on vent capacities- with the proceeds going to charity.
You may have to drill and tap the ends of the steam mains to vent them, but it's worth the effort.
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"All Steamed Up, Inc.
Consulting0
- 87.4K THE MAIN WALL
- 167 Indoor-Air Quality
