Heat Pump Helpers
Wayco Wayne
Member Posts: 615
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=255&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
Remember Heat Pump Helpers?
They were around years ago. The oil companys would install an oil fired water heater and run a heating loop to a back up heating water coil in the duct work down airstream from the heat pump coil. I realyze this is a type of open system, but if you ran the circ every night would that protect the system from bacteria and Legionella? Thinking about it for a job I'm on. Because of additions to the house the main oil furnace is way over sized. It has an existing heat pump. The family has 7 kids, 3 of which are teenagers. Replacing the furnace with a fan coil for the heat pump would free the chimney up for an oil fired water heater which would give them a lot more hot water and back up the heat pump on really cold days. Only a 30000 btu heat loss at 10 degrees. WW
Now Now
> 10 degrees. WW
> _A
> 255&Step=30"_To Learn More About This
> "Find A Professional"_/A_
- 86.7K THE MAIN WALL
- 56 Biomass
- 105 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 948 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
