king valve
JERRY_10
JERRY_10 Member Posts: 6
THANKS, VERY NICE INFORMATION
  • JERRY_10
    KING VALVE
    WHILE CHECKING SOME ENGINEERS PIPING DWGS I CAME ACROSS THE REFERENCE TO KING VALVE ON A STEAM HEADER...ALL THE VALVES FROM THE STEAM BOILERS AND THE VALVES GOING OUT TO THE SYSTEM ARE REFERENCED KING VALVE...
    THE QUESTION IS--- IS THE KING VALVE A GATE VALVE OR SOMEOTHER TYPE OF VALVE??? ANY IDEA'S... THE ENGINEER IS OLD THUS THIS MAY BE AN OLD TIME NAME? THE AREA IS NEW JERSEY-NY.. HELP!!!!!!
    THANKS
    JERRY
  • JERRY_10
    KING VALVE
    THANKS
    JERRY
    Steamhead Member Posts: 17,941
    A King Valve
    is a gate valve placed on a steam main where it comes out of the boiler header. This let the operator build pressure in the boiler for cleaning it out, without building pressure on the system. A valve on the return side was needed also.
    We don't see king valves much these days, except at Mad Dog's house ;-) .
    Consulting
  • A king valve
    is also what the valve on a Vari-Vac steam system was called. This valve fed steam from a boiler with steam pressure into a main that was in a vacuum, and it modulated to KEEP it in a vacuum. This is outdoor reset on a steam system.
    I doubt he has you building a vacuum system, so this is just a footnote to history.
    Noel
  • Weezbo
    Weezbo Member Posts: 6,231
    Bink
  • JERRY_10
    KING VALVE
    THANKS,
    THIS BUILDING DOES HAVE A VACUUM SYSTEM....
    DOES THIS MEAN THAT THERE HAS TO BE A KING VALVE ON EACH OF THE BOILERS FEEDING THIS SYSTEM, AND DOES THERE HAVE TO BE A FIREMAN MANUALLY OPERATING IT TO KEEP THE SYSTEM IN A STATE OF VACUUME???
    THERE ALSO IS A NEW VACUUM PUMP TO BE INSTALLED ALONG WITH THE REPLACEMENT OF THE 4 BOILERS.THIS SHOULD BE INTERESTING TO CONTROL.
  • Mad Dog_2
    Mad Dog_2 Member Posts: 8,311
    Here ya go....
    King valves cannot be beat when it comes to blowing down your boiler. Mad Dog
  • c.t.kay
    c.t.kay Member Posts: 85
    king valve
    "king valves" are a code item in nyc.they are used to do a hydrostatic test on the boiler.
    The valve on a vacuum system
    is usually controlled automatically, as is the vacuum pump. The ultimate vacuum system is (not "was", they still make this thing) as Noel says, the Dunham Vari-Vac. Unlike the usual vacuum system, this one has all parts of the system downstream of the king valve under varying levels of vacuum. In this way the system can vary the temperature of the steam, which means more economical operation.
    Consulting
