Pilots during summer
John_54
Member Posts: 17
I own a 4 floor apartment building with hot water heat. 2 Boilers side by side connected to the same return and supply pipes. I have been advised to keep the pilots burning during the summer to avoid condensation. Is this recommended practice. If so do I need to keep the pilot on in both furnaces or will one be enough. I use straight water in the system no additives.
save yourself some trouble
Leave them both on. It helps the inside of the boiler's and keeps the pilot assembly's from getting plugged up.0
- 119 Geothermal
- 394 Solar
- 50 Industry Classes
