Munchkin 140M delay ignition
Pinball
Pinball Member Posts: 249
  • tim smith
    tim smith Member Posts: 2,886
    Munchkin 140M, delayed ignition, HELP
    Munchkin started delaying ignition, will not start. after appx 2 - 3 seconds after valve opens it ignites with a bang and shuts down and recycles and does same all over again. Spark looks good, flue shows clear. Cleaned slight build up on heat x. Call me if you have an idea at 206-571-6269 or post. Thanks in advance.
  • Timco
    Timco Member Posts: 3,040
    I had a unit do this after a cold start-up...area of burner where gas hits the sparker was blocked by condensation water, so gas was not being sent to the sparker, and would not ignite until the chamber filled with gas...BANG!
    t
  • Wayco Wayne
    Wayco Wayne Member Posts: 615
    Let us know what the factory says
    Be sure the condensate drain is clear. Sometimes I have had to cover the air inlet to get combestion going so I can run a test and adjust the gas pressure. Wonder why it failed after running for so long? WW
  • JohnWood1
    JohnWood1 Member Posts: 63
    Two Causes I've seen
    One is a cracked ceramic insulator on the ignitor, allows spark to partially short to ground. Intermittant problem.
    Two is a break in the burner to faceplate gasket that allows gas/air mix to bypass burner and build till it "poofs"
    Hope this is helpful!
    jw
  • John MacGregor_2
    John MacGregor_2 Member Posts: 32
    Munchkin delay
    We have found at least three Munchkins with loose burners, either the screws were too long or or the tappings had not been cleaned out or they just plain hadn't been tightened properly. Poor quality control, I'd say!
