recommendations
bovide_4
Member Posts: 161
Can you recommend the best choice for:
3 gas hot water boilers + 3: 40 gal. dhw indirects
Heat loss btu's:
basement: 20,400 / 1st floor: 26,500 / 2nd floor: 34,400
Considering three Slant Fin SE 70's with WeilMcLain 40 gal. indirects.
The hot water consumption is not much, so the derating of the indirect's performance with the small boilers seems OK.
The boilers must have MEA numbers.
Heat loss btu's:
- 87.4K THE MAIN WALL
- 167 Indoor-Air Quality
