press tool
singh
singh Member Posts: 866
know if the propress tool , with the stadler head will work with
wirsbo multicor ? Also has used press fittings for oil fill and vent lines.
I usually use 2" black, but I wonder if o-rings with oil may be problem?
I know I can save time from cutting and threading and semi-retire threading machine. Also, when Nibco comes out with their press fittings,will it work with ridgid.
I am seriously considering buying tool this week, one of my suppliers now stocking fittings,and just want to know how much bang I can get out of tool for its large price tag.
  • Kal Row
    Kal Row Member Posts: 1,520
    try the rems people
    http://www.rems.de/go.aspx?lid=2&tid=15&pgid=6
    they make all sorts of "radial" press tools - notice that thye are not advertizing the "propress compatible" even though it still is, as they are under lawsuit from viega -
    so while the germans and italans duke it out, you can buy the remes toolkit and it does a nice job on propress and a whole host of radial pressing needs
    there i am starting trouble again ;)
  • S Davis
    S Davis Member Posts: 491
    Propress
    The Propress will work on Wirsbo Multicore but you will have to buy the Reems Multicore heads from Wirsbo for the propress.
    S Davis
    Apex Radiant Heating
  • jerry scharf_3
    jerry scharf_3 Member Posts: 419
    I thought Rems won the EU case
    Kal,
    It's good to start trouble sometimes.
    I thought that Rems had won that case. Maybe they only won one round...
    I've never quite understood why Viega made soch a big deal over this, the money is in the fittings.
    jerry
  • Kal Row
    got a good rems dealer in the usa?...
    lost the card i got from them at ish boston - tnx
    need a radial prees for the zurn pex
    dont like wirsbo system much, the pex "memory" is way to slow and time consuming when it gets cold - with the zurn system - you slide it on, crimp, done - fraction of the time
  • S Ebels
    S Ebels Member Posts: 2,322
    Whatever you want........
    I can get. Call me at 800-607-6135. I'm going to be on the road/slush a lot until Weds evening but you can get me at that number most evenings after 9PM. ("Rems are us")
