Burnham furnace will not stop running
newyorkhandyman
Member Posts: 1
I am working on a burnham furnace and can not be sure of the cause of the problom. Wondering if anyone else has ran into this before. Problom---Heat stays on and registers 80 on the thermostat no matter where it is set, Also thermostat goes blank after a while, but heat stays on and blower continues to run. I had suspected the original thermostat and changed it out. This worked for about a day and the the problom continued. I am suspecting the transformer although I am not sure. When I unhook the white wire at the transformer it shuts down the furnace and then runs properly for a short period of time then starts to stay on again. any help would be greatly appreciated....STUMPED.
The furnace info is:
Burnham gas forced air (Gas)
Model # P205A WNI
130,000 BTU
Thanks again in advance for your input...Jeff
Model # P205A WNI
130,000 BTU
Burnham forced air furnace??
From the info that you gave, it appears that the heat generating device in this system is a hot water boiler fired with natural gas!
Does the boiler feed one or more air handlers (aka "forced air")?
I would recommend that you call a heating professional who has experience in hydronics. What you are describing indicates a need for such a professional to assist you. Watch how he/she diagnoses and fixes the problem and you will be more knowledgeable on this type of system for the future!0
