Embassy Boiler
I am considering using Embassy's BMS or Axia wall hung direct vent gas boilers for two jobs I'm looking at. The boilers also have tankless DHW. They look perfect for these locations which have fairly low heat loads and space limitations (and budget limitations as these are both first homes for these couples). I don't recall ever seeing these in the field and would like to know what kind of reputation they have.
Are they serviceable? Reliable? Any installation problems?
Any other recommendations?
  • Royboy
    Royboy Member Posts: 223
    Embassy boiler?
    Mark - I was just about to post pretty much the same message as you did and found your inquiry by a search. Seeing no other response to you, I thought I'd revive the thread and see if it fares better now.
    Did you do these installs you were inquiring about?
    I am guessing you encountered the boilers at the same place I did, Houseneeds.com (with a wholesale branch called ProHeatDirect.com).
    In case anyone is curious, the page featuring the boilers is at:
    http://www.houseneeds.com/shop/HeatingProducts/boilers/ambassador/embassyambassadorboilersmain.asp
    Thoughts? Feedback?
    Thanks -
    Roy Settgas
    Sunrise Energy Services
