Vintage plumbing question
Saggs
Member Posts: 174
I know this isn't a heat problem but I'm stumped trying to find help on this subject. I have a 1950's "Standard" porcelain wall mount drinking fountain that needs a hand valve, probably a spring-loaded twist affair. The side hole in the fountain is approx. 1.5" and had a 3/8 flare to feed the bubbler head. Any help would be much appreciated. Please don't beat me up too bad for this "plumbing" problem..
try new york replacement parts.
They carry older plumbing repair parts.
www.nyrp.com0 -
Commercial Heating and Air Conditioning
we are looking to discuss a particular situation with an expert in commercial heating and air conditioning. We are involved in several aspects of an apartment building that has had a major malfunction. the system is 2 - 250HP steam boilers heating 2 - water coils for heat. This same system operates an air conditioning chiller.0 -
Here
Try here, http://www.crogan.com/index.htm
Crogan's Plumbing
They helped me with some vintage faucet parts.
Good Luck,
JimThere was an error rendering this rich post.
Dorsey whats the problem ? this building sounds like many systems we see here in Westchester N.Y.0 -
No beatings for an honest question
I think Singh has you on the right track. Many here were/are master plumbers, including me. Good luck. Mad Dog
you can also check faucetworks in Eastchester N.Y.0 -
Call this guy
George Taylor Specialties
Ask for John.
Tell him John from Gateway Plumbing sent you. Maybe he'll be nice to you.
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 938 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
