Buderus GB142 24
Jamie_6
Member Posts: 710
I talked with Dave @ Buderus yesterday about this sinerio and I wanted to put it on paper so everyone can see it! The baseboard (which are 4 R-22 panals) will run off of the r-10 control. We will be using Buderus outdoor reset controls on the two mix blocks. I am just confused on how to tie it all together????? The zone valves off of the mix block? Because each mix block will have one t-stat on the largest zone which is a Buderus t-stat., and the others will have another t-stat? Any help would be appreciated.
Jamie
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=289&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
Jamie
Jamie
When you talk about a Buderus t-stat do you mean a room sensor ? If so be carefull its very difficult to balance this.
I wuld use traditiona; t-stats for the zones and allow the mixing stations to do thier job.
Nice looking design, is your Dad shaking his head
Scott
Scott,
Yes, I am talking about the room sensor. What do you mean you will have trouble balancing it? Buderus had said that I would need that sensor so the mixing station would operate correctly off of ootdoor reset?
You would just use some taco zonevalves then with a zonevalve control panal?
Thanks for the input!!!!!!!!!!!
I still owe ya some beers too.
Jamie
pretty close
My email is currently down. As soon as it is back up i will forward a revised diagram. You will need a 2 zone circ relay.0 -
Dave,
I never got that e-mail?
Jamie
curious
What program did you use to make that diagram?0 -
The program is Microsoft Viso. Thanks0 -
Hey Joe
Could you by chance tell me where to purchase it or is it something you have? That would make an excellent program to have when doing layout's and estimates...0 -
It is a great program but it is EXPENSIVE!!!
- 86.7K THE MAIN WALL
- 56 Biomass
- 105 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 948 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
