Outdoor reset theory applied to engines
http://www.jeep.com/autoshow/news/hurricane.html
Can you have responsible excess? To test the theory, we equipped both HEMI engines in the Jeep Hurricane with the Chrysler Group Multi-Displacement System (MDS). Depending on the driver's needs, the Hurricane can be powered by 4-, 8-, 12- or 16-cylinders. All of that translates into buckets of torque for climbing obstacles other 4x4 vehicles can't even comprehend. In addition, it has the power and traction to move from 0-60 in less than five seconds.
Here's the specs
Jeep® Hurricane Specifications:
Weight (estimated): 3,850 lbs. (1,746 kg)
Length: 151.8 inches (3,856 mm)
Wheelbase: 108.1 inches (2,746 mm)
Front Overhang: 25.0 inches (635 mm)
Rear Overhang: 18.7 inches (475mm)
Width: 80.0 inches (2,033 mm)
Height: 68.2 inches (1,732 mm)
Track, Frt/Rr: 67.5/67.5 inches (1,715/1,715 mm)
Engine: two 5.7-liter HEMI® engines
Transfer Case: Custom multi-mode with 1:1, 2:1 and 4:1 ratios
Transmission: 5-Speed automatic
Front and Rear Suspension: Long-travel, short/long arm independent
Ground Clearance: 14.3 inches (363 mm)
Break-Over Angle: 31.5 degrees
Approach/Depart Angle: 64.0/86.7 degrees
Tire Size: 305/70R20
Wheel Size: 20x10 inches
I want one.......
Noel
  • Uni R
    Uni R Member Posts: 663
    Outdoor reset?
    It sounds more like 4:1 modulation.
    Maybe that should be 16:1 given the transfer case. =)
